Good Quality Wireless Interior Lighting ???
Anyone have any experience with any decent quality wireless interior lighting ??
LED would be ideal, need for a few different applications.
Brands ?
Brands ?
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
I assume you are referring to battery powered lights?
Yes Sir !
I still havent figured out a better way to get power to them.
But I have also seen wireless switches a few times, to operate a fan or light when there was no wire between the two.
In those cases only the switch was battery operated and the fixture was wired. I am now wondering if the tech has evolved to the point where both switch and light could be battery powered??
A battery-powered switch requires very little power -- a "button" watch battery will last for years.
A battery-powered light requires as much power as the watt rating of the light. Basically you're talking about a super-sized flashlight.
Wireless Lighting
Dan
Yes, battery powered all the way.
Attic crawlspaces, diificult access porch and interior staircase
None of them will be lighted often or intensely, so battery power is not really an issue. And with modern LED's the draw is quite minimal. Not trying to light a workbench or office, just convenience lighting. Was hoping someone might have experience with a good quality brand or system.
Thanks much
There are dozens of such "closet light" systems on the market. You can find them at WalMart, and maybe even your local grocery. Theyre sufficiently inexpensive that you need not be seriously concerned about longevity, and so long as they use LEDs the efficiency (lifetime of a given size battery) should be roughly equal for all brands.
(However, I don't recall seeing any systems with both battery powered light and cordless remote control. The cordless remote would require a receiver to be constantly "listening" in the light unit, and that would drain the battery fairly rapidly.)
I use these in hallways and bathrooms:
https://www.amazon.com/gp/product/B002FCGI8Y
It is powered by four AA batteries (in my case they are low discharge rechargeable) and I replace them every 2 to 5 months depending on where they are installed and how much traffic they get.
