My casement windows have those concealed lever and slide type hinges, made of steel. I want to replace them with old fashioned brass butt hinges. Does anybody have a good source?
Thanks —
— J.S.
Thanks —
— J.S.
You might find yourself replacing more than just hardware. I did this for a client and had to build new sashes to make it possble.
Piffin --
What issues required replacing the sash? Is there a problem with the opening/closing geometry? I'll measure and do some CAD drawings to check that out. The other problem I can see is hiding the dutchmen that fill in where the old hardware was. As this is all paint grade, that doesn't look too hard.
Thanks --
-- J.S.
Part of it for me on that one was that the customer was a purist.
Modern casement sash have a sort of Z shaped edge that facilitates seating tight. Older hardware can require a flat edge on one side and a beveled edge on the other. Needs flat surfaces to mount to. Is less water and airtight than the modern geometry. I would look for a large brass pin hinge rather than a bolt/butt hinge type.
Yes, you can use dutchmen and bondo to fill old holes and cavities.
Clements is a good site.
I got some excellent brass door hinges from http://www.clementhardware.com. They had an ad in FH. They were faster than the local Baldwin store, and less $$. Easy to order, fast delivery, no problem. I don't know if they have the size you want, but it's easy enough to look. You just click around a little and you'll get a nice concise list of what they've got.
Good luck,
B
Thanks, B -- I've sent them an inquiry about supplying all 160 hinges.
-- J.S.
Hey
I might be too late here, but I have gotten some excellent hardware from Whitechapel.
http://www.whitechapel-ltd.com
best,
DC
Hi John, if your in or near california, and actually they ship, There is nothing that crown city hardware doesnt have Steve
Thanks, Steve --
I found Crown City through Google, and they're a drive-to for me.
-- J.S.
Is that a good thing, i have there catalog, they charge foi it, but i love to look at the pictures of good hardware?????? does that make me sick ?? :):) Take care
John,
Try Liz's Antique Hardaware in Los Angeles. They have a website if you're not from the area. I was there yesterday with my sister looking for glass doorknobs. They have it all- door knobs, hinges, fixtures, etc.
Here's the info off their business cards:
453 South La Brea
Los Angeles, CA 90036
323-939-4403
http://www.LAHardware.com
Thanks, Jim --
That hardware store is maybe about 2-3 miles from my house.
-- J.S.
