Quite exited about building my new residence. I have already incorporated green roof into my house design in order to make my structure energy efficient. I need to know few more ways to design an energy efficient home. I am looking for ideas… Thanks!
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
' building my new residence'
does that mean you are actually building it or hiring a contractor? WHY do you want 'green'?
Area of the country? Makes a big difference for actual ideas, e.g. GSHP; or, nat gas heat from local well, Solar insolation? Desert, mountain, swamp, or ice?? etc.
You can get rid of a LOT of 'green' simply following the latest 'green' fads.
If you are doing it only to say 'look how 'green' I am to your liberal friends, spend big bucks on 'certified' designers, etc.
If you truly want to be a conservationist, AND want to save big $$ while not causing any trees to be cut or iron mined, etc., biggest ecological contribution If you are a 'tru believer' would be to buy nearly all your material salvage, surplus, etc. Habitat stores are your friend.
If you DIY build and spend 3 or 4 years accumulating recycled material first, you can DIY build for UNDER $10 sq ft vs. >$200 sq ft if you simply hire a 'green' builder. And that is NOT shoddy level of materials either.
Building below was built for $7.68 sq ft inclusive of ALL materials, plus $1.87 for permits (ugh). 8" wall insulation, SEER 20 HP, etc. Note: the HP was over $1 of the total.
examples: 'fancy window' was a return for $190, list price was $1700
bookcase 100% scrap, muchwas free pallets off craigslist, back was free CL leftover flooring free
lower kitchenette all free from CL, upper ws $5 off CL, micorwave free at a garage sale, needed only a 50 cent fuse to fix.
bobcat is part of own 'tool set'
btw, here is a green roof
I think we all know what a green roof is.That was Junkhound's great attempt at humor...
