Hello All,
My plumber just roughed in my shower components and something doesn’t look right. The setup has 6 body sprays (3 on opposing walls) a rain head, handheld showerhead, and a fixed shower head. In the diagrams I’ve seen on body sprays, I have seen them hooked up using a pressure loop. It has pipes leading into each spray from both sides. My plumber hooked mine up with just one pipe feeding each spray. He says it doesn’t matter. I don’t want to wait until after the walls are tiled to find out this won’t work right. I’m skeptical…. Thanks much, Mark L.
What's in the manufacturer's instruction?
Those spray heads are not too far apart, are they? Water pressure is good? Then I wouldn't worry about it.
