HELP, how do I fill a 10″ wide by 19’long space between a gable end garage wall foundation & cement walk? The space is created by cement walks on three sides & 19’of a foundation which is poured below frost line with two course of 6″ block on top. I just repaired the blocks,the soil was removed down to the joint between the blocks & the poured section. Now I need to fill in about 6″ to make it flush with the walk.
HELP, how do I fill a 10" wide by 19'long space between a gable end garage wall foundation & cement walk? The space is created by cement walks on three sides & 19'of a foundation which is poured below frost line with two course of 6" block on top. I just repaired the blocks,the soil was removed down to the joint between the blocks & the poured section. Now I need to fill in about 6" to make it flush with the walk.
