By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
What are you primary uses going to be?
How large of holes, how often?
Milaukee makes a great 1/2" hammer drill for what I would consider light duty.
If you're frequently going to be drilling 1/2" or so holes and many at a time I'd consdier a small SDS drill like the Bosch 1" SDS plus Bulldog, but then you are limited to SDS bits unless you buy a conversion chuck.
From there you get into more serious drills which I do not think are you looking for
I'm mostly going to be using it for drilling repeated 3/16" or 1/4" holes to fasten wood/metal to concrete. I want something that can also handle occasional larger tasks.-T
Hilti.
J. D. Reynolds
Home Improvements
Edited 12/10/2005 12:39 am ET by JDRHI
If one is available, talk to a Hilti rep. Those guys usually have good knowledge to share, and Hilti stuff is real good. Milwaukee would be a good second choice.
I have the Milwaukee magnum 1/2 inch hammerdrill . No problems, but I drill only smaller size holes with it.
Edited 12/10/2005 9:39 am ET by MarkH
Buy Two. Get a little one for the small holes, and a bigger combo breaker for the large holes and small chipping jobs. I like Hilti as well. A lot. But the Boschs are also good. Never owned a Mil, but haven't found fault with much of their other wares that I have.
A recent issue of JLC had a review of SDS roto hammers (larger than hammer drills, SDS shank bits, no chuck) and they like the Hitachi. It looks a little goofy to me but I might have to get one.
I have a Makita 1/2" hammerdrill that I use for small holes (think Tapcons), but use a Bosch rotary hammer for anything over 1/4", or for repeated drilling. Rotary hammer will take the work right out of drilling concrete. I use SDS max bits, but haven't needed to drill anything over 5/8th with it.
Don't know about the new Hitachis, but I've got an older one that has taken a lot of abuse and is still working like new.
The heck, you say?
I have the Bosch, a great tool. Have used the Hilti, just as good and the Hitachi, no problems there either.
