When hanging an interior door in new construction how much space should I leave between the sub- floor and bottom of the door for carpet clearance,also would you set it closer over a wood or tile floor.
Depends on the flooring choice.1/2" for carpet as a rule.Less for the really cheap stuff.
Mike Clark
1 1/4" door to floor is standard.
You can micro manage this for different flooring, that's why we are all retiring rich...
unless specified just hang the doors as they come.but if you know what the flooring will be then cut to that. if your customer doesnt know what the flooring will be at the time the doors are installed i have an extra charge to come back later to trim all the doors $20 each. some one suggested 1 1/4 as standard . that is way to much.what if they install laminate or thin wood flooring they would end up with 3/4 to 1 inch gap.
actually...HVAC guys will tell ya around a 3/4" gap is needed for air flow with forced air heat.
We usually cut doors swinging over carpet an 1 1/2" over the subfloor(unless otherwise spec'd)...some of those have even rubbed. Even that leaves about a 1/4" space between carpet and door. And in narrow halls with air returns, we've had to go as much as an inch and a quarter above the carpet, per the HVAC installer. Cheap carpet has nothing to do with cutting door bottoms off. If this is not for yourself, the GC should give you the magic number. EliphIno!
Handyman, I said 1 1/4" is standard.
Do you really want to have a problem with that?
Don't make me rip that badge off you now ya hearView ImageGo Jayhawks..............Next Year and daaa. Blues View Image
Come on, watch where this one goes.
Sit back and get ready for some door science.
kView ImageGo Jayhawks..............Next Year and daaa. Blues View Image
I'd ask your flooring installer. Around here, I'd say 1/2" is pretty standard. But some only want 3/8"
Can't imagine why anyone would want 1 1/4", but things vary so much from region to region - That could just be what they're used to doing.
That's part of the reason I suggested asking locally. If your flooring guys want 1 1/4" and you put them at 1/2", they aren't really gonna care what some guys on the internet said.
So often times it happens...that we live our lives in chains...And we never even know we have the key [The Eagles]
I'd be talking about the distance to the bottom of the door, not the jamb and casing. That would 3/8" for carpet, especially since the berbers are in vogue. EliphIno!
I always buy prehung doors. Set the jamb height, and let the door worry about itself.
Since virtually ALL houses around here have forced air heating/AC, I don't worry too much about ventilation.I have the oldest typewriter in the world. It types in pencil.
For new doors: Forget about the spacing although it should be around 3/4 to 1" to allow air flow for ventillation systems etc. Remember the bath fan that wouldn't clear the fog off the mirror because there wasn't enough air comming in under the door?
I hang doors for a living and I can't remember the last time I measured the gap at the bottom of a door.
Cut your Jambs 81 3/4" and set them on a 3/8" shim for carpet areas or tile on concrete.
Cut your jambs 81 3/8" and set them on a 3/4" shim for hardwood or 3/8 shim for tile on 3/8"underlay.
If you have a cluster of doors in one area keep the top of the doors at the same level, adjust the bottom of the jambs as needed to allow for changes in flooring.
Turtleneck
Its not a smile- its a cramp
I am a finish carpenter and had 1 home where the opening was not high enough for the door (rough openinh at 81" from top of subfloor) Gc says hang the door as high as possible- he'll fix later....
The gc was the framing contractor and the home owner so he can have as much clearance as he wants !!!
First thing I thought of when I read yer title was...
How often do you hang the door help ?
Quittin' Time
Oh, and wouldn't bragging about it here tend to tip off the local constabulary ?
: ) A good heart embiggins even the smallest person.
Quittin' Time
No one's even mentioned the most important thing yet......
....making sure all the head casings line up.
Set one...then match it.
"How often do you hang the door help ?"
You shouldn't get "hung" up on technicalities...A conclusion is the place where you got tired of thinking.
What you talkin' 'bout, Willis ? A good heart embiggins even the smallest person.
Quittin' Time
