In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Hardie Repair
BillD60 | Posted in General Discussion on September 15, 2009 09:16am
I recently completed the 34 sq. of siding on my new house.  I used Hardie clapboard – 5″ reveal and hardie trim.  All good and looks great.
Here’s the problem: When I was swinging the lift away from the house, I zigged when I should have zagged and dented/broke a piece of siding.  This dent/break ocurred 10 feet or so down the wall; so I opted not to remove siding down to that point.  The spot is about 3 inches high and 5 inches wide and is more of an indentation than an actual break.  I’m concerned that water will continue to wear over this spot and create other problems.  Is there a recommended procedure for filling or repairing such a spot?
  1. Scott | Sep 15, 2009 10:56pm | #1
    Just guessing.... how about auto body filler?
    Scott.
    IMERC | Sep 15, 2009 10:58pm | #2
    seen concrete vynal patch used...
    looked patched...
    bite the bullet and do a real reapair...
    WOW!!! What a Ride!
  3. MikeHennessy | Sep 16, 2009 03:32am | #3
    "I opted not to remove siding down to that point."
    To repair this, you should be able to replace only that piece of siding that's dinged. You don't have to strip the whole wall down to that point. You should be able to slide a hacksaw blade under the siding and cut the nails on the bad piece. Course, you're gonna hafta face nail the new section, but if that's an issue, you can use trim screws and fill 'em so you hardly (no pun intended) know they're there.
    Mike Hennessy
    Pittsburgh, PA
    Everything fits, until you put glue on it.
    1. BillD60 | Sep 16, 2009 04:03am | #4
      Great. Thanks.  Never even crossed my mind... and my mind has had to cover a number of screwups along the way!
  4. splintergroupie | Sep 16, 2009 06:45am | #5
    You can fix it with Bondo. Knife it off level, thencover with a piece of waxed paper, and tool the Bondo to match the pattern through the waxed paper.
    You may need to rough up the surface a bit to match the Hardie reflectance, but the wood grain or whatever can be tooled in with a dowel if you're quick, or sanded in later if you aren't.
    1. BillD60 | Sep 16, 2009 05:05pm | #6
      Thank you.
  5. husbandman | Sep 16, 2009 05:23pm | #7
    I had to do that on my own house. I did it like Mike H said.
  6. mike4244 | Sep 16, 2009 10:36pm | #8
    I repaired some siding two years ago for an old customer. Her grandson thinks hardiboard is a backstop for baseballs. I used a sawzall to cut the nails. removed the entire piece and reinstalled a new board. I used stainless steel 8d siding nails.
    mike
Building Wildfire-Resistant Homes
13 articles to help you make a new house or existing home safer from the threat of wildfires.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
