Hardiplank on an old house
Autod1dact | Posted in Construction Techniques on September 20, 2011 06:13am
My Hardiplank siding order will be coming in soon.  I’ve never worked with it, but I’ve handled a lot of it and grown somewhat familiar with the product while working for a builder.  I’ve read the heck out of the Best Practice material online, but I’m still wondering about nail length.
My 150 year old house has 1″ pine planks for sheathing, and I’m wondering if I shouldn’t go with longer nails, say 2″.  This way I can be assured of a positive connection to the studs.  I feel like shorter nails will effectively only attach the Hardie to the sheathing.
What would you do?
    MarkH | Sep 20, 2011 07:52am | #1
    I would use 2 1/2 inch nails myself.  But I use a siding gun.  If you are using roofing nails, use the longest your gun takes and try to hit the studs.  But in reality, nailing to the sheathing is probably enough.  I would renail the sheathing before residing if there is any question of the old fasteners.
  2. HarryLudke | Sep 20, 2011 06:55pm | #2
    I resided my old 170 year old farmhouse with Hardiboard a few years ago. It's the old post and beam with 1" boards nailed vertically on the top and bottom beam. The end result turned out great!
    You don't have to worry about nailing into studs. The old boards have more than enough structure to support the Hardiboard. Just nail about every 2' and hang the Hardi. It's actually easier than new construction since you don't have to find the studs and snap vertical lines to make sure your into structure.
    I used a siding gun with 2 1/2 " nails, galvanized ring shank. A siding gun is highly recommended!  Makes the job much easier. If your working alone, your Hardi supplier should also be able to supply you with siding hangers. The hangers let you nail 12' lengths by your self with excellent results and little stress.
    When the siding was off I took the opportunity to seal all windows with Grace flashing and foamed all board joints and holes.
    Good luck!
    1. edwardh1 | Sep 21, 2011 09:17am | #3
      Hardie is great stuff
      no oozing, warping, splitting, twisting, rotting, cracking, alligatoring, paint popping  and all that  wood stuff
    2. edwardh1 | Sep 21, 2011 09:17am | #4
Fast, Accurate Wall Framing
