In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Hardiplank over foam insulation
RodK | Posted in Construction Techniques on October 16, 2005 09:28am
I’ve heard that hardiplank cannot be applied over foam insulation as hardplank can fracture due to it flexing when nailed. does anyone have experience with this?
Thanks,
rod
  1. butch | Oct 16, 2005 09:48pm | #1
    I've applied masonite siding over foam before
    and the only way to do it was with a nail gun as
    the driving force of a hammer would cause the
    foam to compress. I don't know what the concrete
    manufactures suggest but you might want to check
    with them.
    Don't know if this helps...
  2. r | Oct 17, 2005 04:05am | #2
    I have no experience, but the second line of the Hardiplank installation instructions says, "Hardiplank lap siding can also be installed over foam insulation up to 1 inch thick".  They say just increase the length of the fastener by the thickness of the foam.
  3. shaarsta | Oct 17, 2005 08:43am | #3
    I sided my house with hardi-plank with 1" super-tufr foam insulation panels being used as the underlying sheething. I did not have any problems and have had good results. I used nail gun to install the siding, being sure to hit the 2x4 framing underneath. I was woried about missing the 2x4's and so I set the air pressure of the nailer on the low side so the nail would not shoot completly through the siding. Oftentimes however, the nail would not go in completely and so I had to hammer by hand the nail, but I felt that this was a minor inconvenience, for if I did miss the framing, it did not cause overly extensive damage to the siding.
    I did not have any problems with the sheething compressing around the nails.
    Edited 10/17/2005 1:47 am ET by shaarsta
  4. drbgwood | Oct 17, 2005 02:41pm | #4
    I've never done a whole house, but I do alot of rotted masonite removal and replacing with hardi.  I also remove the rotted building board and replace with foam.  Haven't had any nailing problems yet.
    Where I can blind nail, I use the gun.  Where I have to face nail, been useing those gav hardboard siding nails.
  5. moltenmetal | Oct 17, 2005 02:44pm | #5
    The planks themselves can handle quite a bit of flexure without breaking. The 5/4 cornerboards cannot.  Just the flex of the pallet when they unloaded it from the truck with the forklift was enough to do in all my cornerboards- every one was broken through in at least one place.
    Guess XPS (the pink or blue extruded polystyrene) as an underlayment would be less risky than EPS because it's more rigid.  Dunno if you can get the higher density (1.5 or 2#/cu ft) EPS in thinner sheets, or it too might be an option.  I'd be worried about having a really touchy installation if you went over the cheap 1#/cu ft EPS foam without furring.
    1. RodK | Oct 17, 2005 03:59pm | #6
      Thank you very much everybody, that gives me a much better understanding of what can be done, All the best,Rod
Reusable Flood Bags for Fast Bulk-Water Control
These bags from Quick Dam arrive compact and swell to form a protective barrier on contact with water.
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
  • Fastener System for Solving Deck Fascia Board Expansion
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
