Hardiplank:
Seems the installation instructions recommend “Score and Snap”. I Imagine a “score all” and a square to guide it.
Do you score the front or the back? How deep?
I’ve put up lots of wood siding, but never had to cut concrete siding before. A client is asking about it.
Thanks for any help.
scoring tool from the tile depart at any BB...
score the front and snap... use the square to guide...
but you might as well get diamond blades fer yer saw and grinder...
get / use a shear and make yur life so much easier...
WOW!!! What a Ride!
What IMERC said, buy the sheers & learn to use them, there's none of that carcinogenic dust to deal with. Porter Cable makes a nice set. Amazon.
the Ketts are even better...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
I have the Kett shear that you can switch from one drill to another. You're right, I just couldn't think of the name.
I wish I had a Kett, and I will the next time I take on more than a small install, but....
I score the front about 3/16" deep and snap; leaves a clean visual line.
Troy Sprout
"D@mn... forgot the screws."
120$ for a Kett shear head... 5/8"model... 190$ for thr whole kaboodle...
will save enough labor in one day to pay for it's self...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
I have a Kett shear and nibbler set for steel roofing and siding. Since I can convert it from shears to nibblers by switching heads,.. got me to thinkin.
Wonder if the f/c head would fit my Kett body? Could work the other way around too? One drill body and multiple heads sure beats $190 fo seperate kits for each task.
Ever checked into it?
Dave
yup...
that's what I did... got the shear head for 5/8" thick....
sweet....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Thanks.
I've got some tile backer board to cut in the future. It will be a lot nicer to cut it with the Kett shears than a angle grinder and diamond blade.
Dave
