hardwood floor over concrete slab
I need to lay hardwood flooring partially over a concrete slab. This slab section is about 200 sq ft out of 400 sq ft. The remainder is subflooring. I am trying to only raise the floor level the minimum amount. Can I glue this section with permanent results? If not, what are suggestions for attaching cleats to the slab, and minimum thickness of the cleats?
Gregg Tompkins
min. 1/2 inch "cleats", put down with tapcons or offset nails
do not forget a moisture barrier!!!
