Help…….
Has anyone successfully used a 3/4′ T&G flooring product in a below grade application over a concrete slab. The space is occupied and heated.
Does bamboo fit the bill ??
Signed,
On my knees with a PortaNailer in Boston.
Help…….
Signed,
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
I can't think of anyone that recommends their product for being glued to a below-grade slab.
Most recommend some variation of the following:
There are other techniques available. Some are regional. Check the various bamboo manufacturers. If I recall, some say "no" to installing their product below grade regardless of how you install it. Some say you can install it below grade, but no glueing to the slab. Yuo mention 3/4" products...most bamboo is 5/8ths or thinner.
Even though the space is heated, it may need to be dehumidified in the summer.
Wide bamboo plank samples I've gotten from BambooHardwoods have cupped. I don't like their lamination techniques, either. TimberGrass makes a nice product...I'm in the middle of installing TimberGrass right now.
Nothing really works well in a wet basement...ensure that there are no liquid moisture problems year-round.
Thanks Mongo:
Thought I might lay sleepers, rigid in between. poly over, plywood and then nail down the T&G. On you advice, I'll contact TimberGrass, since that's what I'm using....
Order up, .....the next round's on me.
