We are building on a crawl space foundation. Can hardwood flooring be applied over Advantech? If so, what type of installation and vapor barrier is recommended?
Finally, the Advantech is swelling at the seams. Can these areas be sanded down?
Thanks for your help.
absolutely... it makes a good nailbase for the oak.. try to hit your joists anyways.. but in between is ok too..
now.. as to the swelling ..
we've been using Advantech since they came out.. i've been building in wet and snow with it since then.. i've never seen Advantech swell... which is the main reason we use it..
it is Advantech , right ?
have you called Huber or your lumber yard rep to come out and look at it ?
this is pretty important.. it is the only reason people buy Advantech over the competition
