Have you seen PHOTOTOP???
vintage1 | Posted in Construction Techniques on April 3, 2007 12:18pm
I had a countertop fabricator come out today to template a job.  The guy shows up w/ only a yellow briefcase and is ready to template the job.  No luan, cardboard, plastic or anything else.
He put this black spotted tape on the walls, and on critical points on the cabs.  Then he proceeded to lay out several 8×10″ black and white spotted plates in a sort of random pattern on the tops of the cabs.  Finally, he takes several digital pictures of each plate and overviews of the whole thing. The field time was under an hour.
He tells me that some NASA engineers developed this system.  From what I understood, the pictures are fed into a computer program that measures all of the necessary dimensions based on the spacing between his dotted tape and these dotted plates (my oversimplification).  The developed drawing is then projected onto the stone and I assume a CNC saw does the rest.
I thought it was a really cool system, but I did request that they send me a hard copy of the drawing prior to fabrication, just so I could verify we both “saw” the same thing on site.
Anyone else ever see this setup?  Good, bad, or otherwise?
http://fabchoice.com/phototop.html
  1. FastEddie | Apr 03, 2007 12:20am | #1
    I read a brief article somewhere, might have been JLC 2-3 years ago.  And it's like you say: random targets.  Somehow they can convert it to a very accurate layout.
    BillHartmann | Apr 03, 2007 01:00am | #2
    I saw such a system used a couple of years ago on both This Old House and Hometime.
  3. woodroe | Apr 03, 2007 01:33am | #3
    They've used the system on my jobs many times. Never had a problem. Kind of like GPS for your countertop.
    1. vintage1 | Apr 03, 2007 03:31am | #4
      I guess I am just behind the times.  I think it has a lot of possibility.
      I am glad to hear that others have successfully used this system, or at least their sub's have.
      Thanks.
      1. woodroe | Apr 04, 2007 01:43am | #5
        I have some granite tops going in Thursday that were "measured" this way. I'll let you know how it went.
        1. vintage1 | Apr 04, 2007 03:12pm | #7
          Thanks.  I'm interested to see how it goes.
  4. calvin | Apr 04, 2007 03:16am | #6
    Here's one on Templating
    http://www.quittintime.com/
    1. vintage1 | Apr 04, 2007 03:19pm | #8
      Calvin,
      Thanks for sharing.  I see that your project was done in 2004, now I really feel behind ;)
      My guy didn't have a laptop or pointer.  What I thought was interesting was the use of the photos for measuring.  I assume that they are able to take multiple measurements comparing the size and space between the dots based on the known dia. of the dots.  It just struck me as odd since I have had absolutely no luck in trying to accurately measure anything from a photo before.
      I trust that it works.  It just takes a while to get my head around something like that.  Kinda like when I first started using digital cameras, I was worried that all the images would be lost on the memory card because I didn't have that physical roll of film.
  5. karp | Apr 04, 2007 04:21pm | #9
    First time I saw it was about a month ago, stair guy used it for double winder layout. Cut the stringers on a cnc. Stairs are in, look great. Please don't ask me how it works, I'm still stick ticking.
Butt Joints in Decking
Avoid rot and split wood by positioning butt joints on a flat block with a dado for drainage.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
