Helical Ramp Framing
| Posted in Construction Techniques on January 13, 2005 09:12am
O.K. all circular stair guys and others…
Has anyone here ever framed up a helical ramping deck?
If so how were the “stringers” for the decking boards framed?
Is there any way to get away from gluing up helical stringers?
Snaglpuss
  1. UncleDunc | Jan 13, 2005 11:24pm | #1
    What's the radius?
    1. Snaglpuss1 | Jan 14, 2005 03:23pm | #3
      Inner Radius is 75 3/4" , Outer is 111 3/4".
      This is a spiraling ramp not a circular stair.
      It is an outdoor deck type structure.
      1. MikeSmith | Jan 14, 2005 04:12pm | #4
        when the temp. gets right.. i think i'd glue up my own in PT and epoxy...in placeMike Smith Rhode Island : Design / Build / Repair / Restore
  2. maverick | Jan 14, 2005 12:36am | #2
    you could stick frame under each tread if you have the room underneath. I built a winder that sits an two walls at 90 degrees with a little help from autocad
Scaled to Suit the Site
This thoughtfully designed home preserves the character of its neighborhood while maximizing space for a growing family through careful attention to scale, rooflines, and material choices.
  • Sharp-Blade Solution
