Help Make These Stairs Safer
stevemac01 | Posted in General Discussion on August 15, 2019 09:23am
This is my son’s home from upstairs. Here are the problems:
 – Short discontinuous handrail
 – Top bannister’s are poorly attached and wobbly
 – Wobbly newel post
Caveats:
 – I have doubts we can easily remove ceiling below for access to add blocking
 – The spindles are loose and thin but they match the lower bannister
 – His first home and he’s got many items competing for a limited budget
The simplest solution I could think of is remove the upper bannisters and put in half-walls but some think it will ruin the looks.
  1. ktkcad | Aug 15, 2019 07:50pm | #1
    You will need to mount any half wall securely to the floor which means opening it up anyway. So open it up and fix the banisters right. Then run a continuous handrail from top stair nosing (even farther is better) to bottom newel post. Yes, it 'conflicts' with the looks of the banisters but is better than the cast on your leg after you have fallen down these stairs.
  2. VICarpentry | Aug 16, 2019 12:32am | #2
    You might find you have joists under those newel posts. If so you might get away with drilling 7/8"x 10" long holes through the floor and newel posts and epoxy 3/4" threaded rod at both ends. Alternatively you can drill the holes 1/16" skinnier than the threaded rod and screw them in to the posts with vise grips and then the posts to the floor. Also a good strong handrail attached to 2 points along the lower wall will stiffen the ballaster once attached significantly.
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
