Help needed with doorway trim.
MBaybut | Posted in General Discussion on July 30, 2006 05:01am
Hi,
I’m just doing a couple of arched doorways and I was thinking it would look good to put a trim around them but I’m unsure what to use and how to do the arch. I will be painting it so it needn’t have to be wood. Could I use styrofoam insulation with a couple of coats of drywall mud?
All help appreciated.
Mike
  1. temujin | Jul 30, 2006 06:30am | #1
    Use MDF. there is always no VOC MDF if you are concerned with VOCs. If you have a few doors you could probably build a template. Or use a circle cutting jig, and cut all the trim, in case  the arc is a circle. In case of an ellipse build a template. Cut the template a little big and then sand the edges to the line. You have your template. You can cut any profile you want on the trim with a router. mdf is the choice of material for paint grade.
  2. FastEddie | Jul 30, 2006 06:56am | #2
    Check the ads in FHB, or a full service lumberyard.  Flexible trim is available in a variety of profiles.  Or look in the Outwater catalog on-line.  I think they have it too.
Fine Homebuilding – July 2023, Issue #316
Find online articles on timber-framed solar canopies; the right footings; the best toilets; choosing insulation; compact cordless routers; and much more.
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
  • The Right Footings for Strong Foundations
  • Tool Test: Compact Cordless Routers
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
