Hi,
I work in a barber shop that as 4 sinks and a washer dryer. If more than one sink is being used at the same time the hot water turns to a trickle. I had a look at the water heater which looks plenty big enough but I noticed it has 3/4 copper going and 1/2″ coming out. Would I get more hot water pressure if the 1/2″ was changed to 3/4″ Any advice welcome.
Mike
Probably piped with a combination of copper and galvanized without a dilectric coupling separating them. The pipe is internally blocked off with a build up caused by the disimilar metals.
I have seen a similar situation caused by exactly this.
Good luck,
Karl
