In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Help on designing a staircase
phemt | Posted in General Discussion on August 30, 2004 05:49am
I need some serious help on designing a a staircase that starts in a basement that goes up to the first floor. To begin with, the width is only 30″!
The dimensions are as follows: Height from basement floor to first floor is 96″. The length (from the first floor landing to the exterior wall )  is 146″ The problem is that there is a 33″ door way (on he same wall as the stair stringer) to another room where the stairs should end. Either I can use 113″ as the length (146″-33″) and make steep steps or I can make a small landing and try to put in a door longer than 80″. Any suggestions?
Thanks for reading.
PHEMT
  1. kclarson | Aug 30, 2004 09:09pm | #1
    (13) risers at 7.3846" and (12) 10" treads = 120" would be IRC 2000 code approved but won't work in your case. Also, the 30" width is not code approved. In our city, an ammendment to the code allows a maximum 8" rise and 9" tread. You might want to check your local ammendments for something similar. If you used (13) risers at 7.3846" and (12) 9" treads, that would give you a total run of 108" which appears to work in your situation.
    1. DougU | Aug 31, 2004 04:59am | #2
      What about the head height? Sometimes going down stairs there is concern for head height. I dont know the min. height off the top of my head? ha ha, that was not meant as a pun.
        Sphere | Aug 31, 2004 05:10am | #3
        go there and fix his stairs, I'm under 6'8''..thats all ya need
        and come by here and fix my router..ok?
        Gunner an Imerc said ya would..
        1. DougU | Aug 31, 2004 06:31am | #4
          I read about your router problem, I think someone mentioned the speed control thing, I remember a Bosch router that did the same thing, it was the variable speed control that did it. Somebody in the shop bypassed it? They did something to it, it had no variable speed but it worked again.
          I use the 7518 for the big bits. Its a horse.
            Sphere | Aug 31, 2004 06:50am | #5
            thanks Doug, I wanted to address it to you, sorta, but didn't wanna step on any toes...ya know?
            I like the router, not the eletronics.
        CapnMac | Aug 31, 2004 06:54pm | #7
        the min. height
        If memory serve correctly, it's 84" above any tread--which is supposed to prevent having that smack-you-in-the-head 'bulkhead' on the stairs.Occupational hazard of my occupation not being around (sorry Bubba)
      3. kclarson | Aug 31, 2004 07:08pm | #8
        The IRC requires 6'-8" of clear headroom. This is measured vertically from the imaginary line created all the tread noses.
    2. phemt | Aug 31, 2004 12:25pm | #6
      Thanks for the help. I used your numbers and was able to add an additional 9" by taking ou the entire door frame, as well as the header that was above the door. It all fits now. Thanks,
      PHEMT
Beth Pointer: General Contractor, Kitchen and Bath Remodels
Beth talks about her company's work remodeling kitchen and baths, what it's like working with the housing stock in Baltimore, and the unique goals and values that drive her business.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
