Help on insulating attic crawlspace
| Posted in General Discussion on February 1, 2001 09:47am
I’m looking for some advice on insulating the crawlspace area of my 1 1/2 story 1939-built home.
Typical of most homes in my neighborhood, the center area of my attic is finished and the walls and ceiling of this area are insulated pretty well; R13 in the walls and R19 in the ceiling area. There are plastic baffles running against the roof sheathing to provide about a 1″ air space above the insulation along the sloped portion of the ceiling. Also, the peak and the crawlspace area of the roof are vented with box vents. (only 1.5″ soffits so no vents in this area)
The problem I have is that the crawlspace area only has blown in insulation. Since the floor of this crawlspace is storage area, I am limited to how much insulation I can add. With what little I have, I currently get ice dams.
In the crawlspace area, can I continue the baffles down to the soffit and add a layer of R19 insulation between the roof rafters? This would basically insulate the floor AND ceiling of these triangular storage crawlspaces. Any advice?
  1. Bill_Kinter | Feb 01, 2001 09:47am | #1
    I'm looking for some advice on insulating the crawlspace area of my 1 1/2 story 1939-built home.
    Typical of most homes in my neighborhood, the center area of my attic is finished and the walls and ceiling of this area are insulated pretty well; R13 in the walls and R19 in the ceiling area. There are plastic baffles running against the roof sheathing to provide about a 1" air space above the insulation along the sloped portion of the ceiling. Also, the peak and the crawlspace area of the roof are vented with box vents. (only 1.5" soffits so no vents in this area)
Build a Transom Above a Stock Door
A decorative transom fills in the space between a stock door and the home's 9-ft. ceiling, saving the cost of a custom door.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
