Help with marble counter
CardiacPaul | Posted in General Discussion on May 6, 2007 04:44am
I made up a marble counter top in one of my bathrooms a few years ago. The marble is a light  tan, cream with some reddish & brown veining, Its from Turkey.
My problem is maintance, cleaning solutions used on the porcelain sink & facet have  gotten splashed on some areas of the marble leaving dull spots, result of mild acid etching I’m sure. What do I use to re-polish the marble to it original high gloss surface. I would think it is a process rather that a single product.
Thanks for any help
Paul
  1. jackplane | May 06, 2007 07:35pm | #1
    A good wax with carnauba would be the simple fix. But it'd require periodic rewaxing. Another option is to sand the area, starting with probably 320g and working up to 1500g or so; the paper is found at auto supply,auto body houses.
    The higher the grit, the more it buffs out to a gloss level.
    Expert since 10 am.
