Hello,
I’m an architect (in Ohio) designing a wine cellar addition to a residence … and we are wanting to use (most likely?) horizontal redwood or cedar as our exterior material on the project … a colored stain or paint is highly undesirable. Conceptually, I am wanting to create a “case of wine” by literally wrapping the exterior walls in the same material wine is shipped in … but the obvious fear of weathering, turning grey, etc., seems to be a likely result. What is the best clear finish (oil, urethane, varnish, etc.) to use on either of these woods to (for lack af a better description) “keep that fresh new wood look”? Would another species of wood be a better solution? “Marine grade” products/finishes seem an obvious possibility? Teak oil was suggested, but manufacturer’s data suggests denser woods (teak, rosewood, mahogany) which are likely more expensive.
Help! Thanks!
Cabot's Clear Solution...probably the best product for cedar (and redwood)...
http://www.cabotstain.com/shared_frames.cfm?area=towoca&cabot=1
Or you can even use a semi-transparent stain (Cabot's & Olympic are the top choices) in a color that mimics the original woodtone..
Edited 1/26/2006 3:30 pm ET by MJLonigro
Most cellars have concrete for an exterior finish. what am I missing here?
Cabot's is good, CWF used to be a first choice, but it needs attention every couple years, in my experience.
It's actually an above grade "wine cellar" ... thanks to modern technology!
No matter what you use, you will need to re-apply every 3 - 5 years; UV burns off any finish without solids in it. C.R. writes about these products at least once a year.
Advocate
Is that perhaps why some have suggested to me to use a penetrating oil rather than a "finish"?
Nope. Penetrating oil is the stuff that needs to be re-applied every 3 - 5 years. Clear laquer-type finish will chip and flake off sooner and be a mess to refinish.
Read the C.R. article. Most recent one was July, 2005.
Advocate
Pardon my ignorance ... the "C.R. article"?
C.R. = Consumer Reports
Advocate
Try Hardie plank in a cypress pattern. Otherwise the wood will have to be repainted every few years because the wood will rot warp pop twist, leak sap , crack and bow. Life is too short to spend it painting and repainting wood.
wood- a 4 letter word, not good exposed to the weather. also know as flammable bug food
Edited 1/26/2006 7:54 pm ET by edwardh1
Frankly, what you want doesn't exist. You're better off with a good quality semi-transparent stain (Sikkens or Cabot), though even that won't provide 100% protection without a lot of maintenance.
happy?
