saw va couple of roof overs being done…
archies ove three tab and archies over lock tabs…
oversized drip covered hid the old drip edge…
if I’m not mistaken no of this will work…
correct???
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming <!—-><!—-> <!—->
WOW!!! What a Ride!
you can go over three tabs, not sure about lock tabs
with 3 tabs you gotta cut the 2nd course back or you'll get a big bump right there
drip edge over drip edge with render the gutters unserviceable
define work.
Over three tabs not so bad if carefully done but warrantee may be no good. archies over tlocks would look like hell and definitely not live as long as they should.
didn't think so....
WOW!!! What a Ride!
Are you suggesting the hacks from down below here are migrating up into the hills?
not up in the hills...
WOW!!! What a Ride!
