In my son’s room, we are finishing out the small area that is between the floor and a 6 ft wall that was left from a 12/12 pitch roof. It is his Batcave (did I mention he is 6 yrs old?). Anyway, a few years back in FHB, I ran across a short blurb about hinging a bookcase to serve as the door for this area – the hinges were hidden, but did not bind against the wall, there was even a hand sketch to go along with the explanation. Question: what issue was that in, or does anyone have good ideas about building the bookcase (a triangle that is 4ft tall and 4ft across the bottom) that has hidden hinges for a 6 yr old’s Batcave?Thanks.
MtnBuilder
Type in hinged bookcase in the Search box at the bottom left.
Several threads come up.
J. D. Reynolds
Home Improvements
For FHB to to the Home Buiding, Remodeling, and Design link above.
Then FHB. You will need to look around, but there is a magazine index.
You can try both the Alphabetic buttons and a keyword search. IIRC the key word search will not work correctly on multiple worlds.
So try, one by one, hinges, bookcase, and hidden.
