At Amazon, it’s like $10 less than the DW718, and weighs about 10 pounds more. The slide rail design allows it to go up close to a wall.
What do you think?
What do you think?
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
The fence sucks is what I have heard.
" the best investment in life, is a handle on love''
I also read that there's a design glitch where you can't make a 45/45 compound miter without cutting through the fence. Whoops.
Yea but once you do wouldn't that make it more available to make that cut in the future!
And you'd get a splinter free cut!!!
My Hitachi 10" has the same issue, and I already knicked it. That part of the fence is hinged and flips out of the way if you think of it in advance.
Made in China!!
Bruce
Mounted and stationary, it would be a wicked addition to any shop. I would be worried about the LCD's getting trashed if it were mobile.
The detent release on the tillt and bevel are equipped with knobs that allow you to dial in measurements to a fraction of a degree.
I've got a buddy with one in his cabinet shop, he was pretty happy with it.
what's that War of the Worlds thingy on top ?
carpenter in transition
They say it is the miter display. Not where you set anything, just a readout.
I wonder how durable it is. I also wonder how it might help when multiple folks are using the same saw, and someone leaves it set to some small back-cut angle, rather that rezeroing the unit. Would it help if, say, "2 degrees right" is staring you in the face, rather than "zero."
I was thinking " The Day of The Trefids" (sp?).
I've used quite a few different mitre saws over the years being a trim carpenter. I think hitachi's older trim saws were great before they got all space age. I don't think you can find a better 12" slider on the market that is more comfortable to use than DeWalt's.
Wouldn't it be great if Hitachi made a saw just like their 8 1/2" that cut thru a 4x4!
My 10" Hitachi will cut 4x4's and is about the same as the basic 8-1/2" SCMShttp://www.amazon.com/gp/product/tech-data/B00007J8CG/ref=dp_nav_0/102-2306775-3196964?%5Fencoding=UTF8&n=228013&s=hiI think I like it better than the new Hitachi 12". My old Hitachi is a simple, rugged, and accurate tool.
