HOME EFFICIENCY
ZEROTOLERANCE | Posted in General Discussion on December 12, 2006 02:51am
BECAUSE OF SUCH TIGHT BUILDINGS (SEALING EVERY CRACK WITH FOAM), VAPOR BARRIERS, HIGH EFFICIENCY HVAC, AND MAKE-UP AIR UNITS,  WHY NOT USE THE TYVEK ATTIC WRAP TO COMPLETE THE “SYSTEM” IF INSTALLED PROPERLY …TO ME … IT MAKES SENSE.   WHAT DO YOU THINK?
  1. calvin | Dec 12, 2006 03:50am | #1
    Too many capitals.
    http://www.quittintime.com/
    BillHartmann | Dec 12, 2006 04:58am | #2
    We have a Zero Tolerance to ALL CAPS.
    What is Tyvek attic wrap? Never heard of it.
    Hey every group has to have one. And I have been elected to be the one. I should make that my tagline.
    1. jrnbj | Dec 12, 2006 06:39am | #3
      I've seen it advertised...looks like a new use for the same old tyvek.. I had my doubts...
  3. paul42 | Dec 12, 2006 03:47pm | #4
    I think there are several better ways to do the job.
    CapnMac | Dec 12, 2006 07:52pm | #5
    Are you meaning to wrap the house wrap up around the roof, or up and under?  IOW, over or under the roof deck?
    Those places that require that you have a vented roof will, of course, not allow either installation (or will make you hoop jump for variances).
    "Draft sealing" the roof deck only makes sense (to me) if you move the insulation from the ceiling to the roof surface, too.  If so, then, to my thinking, you have to have an infiltration barrier at your moisture/vapor barrier plane.
    Now, just draft sealing an attic actually might add some problems.  You'd then be "adding" the attic to any leaks/penetrations through the ceiling plane.
    More details, perhaps?
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
