How do I cut subfloor around lolly columns?
I’m finishing my basement and I’m starting on the subfloor. I’m putting down 1″ rigid foam insulation then 3/4″ plywood. My question is, how do I cut around the support columns? Thanks for your help.
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
design
Do your layout of the cutout and then decide how you want to split the whole sheet across that cutout. Do the foam one way, the plywood another way. You probably are staggering the seams in foam/ply also.
