How to find the radius or an arc ???
| Posted in General Discussion on July 25, 2001 03:11am
I need to know a mathmatical formula that will give me the radius of a circle if I know the distance between two points of the circle and the distance from that line to the outside of the circle. Basically I have been building walls that have an arc and I know where each side of the arc should start and how high I want the arc to go but other than using “string art” or trial/error method I can’t find the radius and I know there has to be a way.
Thanks so much for your help!
  1. Fat_Diesel | Jul 25, 2001 03:11am | #1
    I need to know a mathmatical formula that will give me the radius of a circle if I know the distance between two points of the circle and the distance from that line to the outside of the circle. Basically I have been building walls that have an arc and I know where each side of the arc should start and how high I want the arc to go but other than using "string art" or trial/error method I can't find the radius and I know there has to be a way.
