hello, i was hoping somebody could tell me how to patch a hole in my chimney’s clay flue where the old owner apparently had vented a wood stove, and then had removed the wood stove and only covered the hole in the chimney with a piece of galvanized tin. the flue will only be used for the oil burner. thanks in advance for any info…
There's a constant source of clean water for you to use, and all you have to do is collect it.
Grout a piece of stainless steel sheeting over it with fire clay, then cover the stainless with 1/2" or more of fire clay and finish off with masonry to match original.
firebrick and mortar.
thanks to all for taking the time to give some much needed advice. goin with piffin on this one, just brought home the firebrick and mortar. hopefully be able to check this off to do list by tonight
