Ice back up spoiling a paint job
Heres a picture taken yesterday – the day after a 16″ snowfall.
Back up is coming thru the eaves and stained water and ice is ruining a paint job from last Summer.
I’ve got to take down this chimney , remove all flashings and then sheath it in and slate it.
I’ll have a chance to analyze the gutters and back up then.
wow walter you had 16" of snow and thats all thats left after a day? must be gettin close to spring!!! :)
Mike,
Thats a slate roof so a lot of it slides right off after building up a ways.
We're getting highs around freezing most days now - plus we're two hours richer on daylight.
Walter
What's up with that hip?
http://www.quittintime.com/ View Image
Theres a piece of old zinc hip cap thats blown off I'd say.
I'll be setting up to remove the chimney today so I'll get a better look.
It looks like somebody did a halfast job of re-topping that chimney once upon a time.
We got 12" out of this storm, but it was so wet and dense it was worth a good 18" or so. My right wrist and elbow and shoulder feel broken from all the shoveling. Lost power for nearly a full day to boot
They sure did !
You can tell from the bottom that it was an elegant top in the early 1900's.
They direct vented a new boiler since all the fireplaces made a stainless liner too difficult they claimed.
You had more water in your snow - ours was heavy but not wringing wet.
now that it has settled and re-froze, watch out fro floods if it rains friday.We are using the good weather today to install a skylight.
Walter- i have seen a good amount of that so far this year while out giving estimates.
One case almost as spectacular as the one you showed.
If we get the project I want to take pictures of the stains to use as a tool in explaining how much ice gaurd we install-----and how one 36" stip of icegaurd at the eaves probably won't perform adequately.
stephen
Stephen,
There's nothing like good pictures of a bad situation to help people understand the necessity of preparing for the worst case scenario.
I have lots of Shutterfly albums on most situations you can encounter with slate roofs , so then it's easy to send one out by e- mail to help show the problems that a particular client might have.
Took that chimney down today and I'll probably do the same with that sequence of pictures - put them in an album as well.
Best regards , Walter
Hey Walter.
Might want to rest those arms.
Storm coming thru Philly tonite. Think it is headed your way.
Chimney looks like a house I worked on last summer. Someone had flashing backwards between chimney and sidewall under slate and had been leaking for years.
5 slates were removed to fix it. Customer got off cheap.
I'm gonna upload some picts if I can of the barn slate/metal roof transition. Its ugly.
I don't think he'll be on that roof monday. We're supposed to get 10-14"snow tonite and monday
Me thinkith you correct.
Were slated to get 8-14 overnite thru all day. Gotta re-group and figure out my new schedule.
BTW wanna see some quality slate repairs.
Check out my picts on general discussion "slate roof transition repair" I just posted.
Jeff,
With these two items I hope to save the arms for more useful ventures.
I've looked at your thread and will be responding shortly
My wife likes red stuff. I'll have to get her one of those red things
