Install J Bead
housenut1 | Posted in Construction Techniques on April 8, 2010 07:06am
Is there anything special about the installation of a metal J Bead to make a finished edge.  I assume the long side of the ‘J’ is installed on the room side.  The metal is very smooth, unlike metal corner bead.  Does the mud (I’ll imbed it in all purpose ready mix) stick to this stuff?  Is it attached with drywall screws too?  Thanks for a reply.
Mike
  1. rlrefalo | Apr 08, 2010 07:20pm | #1
    The J bead I've seen installs with the long leg on the back side , no taping or mudding on the exposed side. Screws can be run into the long leg from the face.
    1. housenut1 | Apr 09, 2010 12:22pm | #4
      Thanks for the advice.
      Mike
  2. calvin | Apr 08, 2010 09:32pm | #2
    If you wish to cap the edge of drywall and leave that exposed, then J-bead might be the answer.  And I've seen people that mudded over the face of it  (like you would a corner bead.  But, it probably could crack at that joint with any kind of movement.
    If you are butting the drywall against something and want a nice finish, take a look at "L" bead.  It's meant to stop or cap and edge, yet lets you mud over it very much like corner bead.
    1. housenut1 | Apr 09, 2010 12:23pm | #5
      Calvin:
      I am glad I asked, thanks for the advice.
      mike
      1. calvin | Apr 09, 2010 12:48pm | #7
        I'm sorry, forgot to include the link
        Here's a link to trimtex.
        J/L bead might be what you are looking for.
        http://www.trim-tex.com/productsindex.htm
  3. calvin | Apr 08, 2010 10:00pm | #3
    check this out.
    Got to J / L bead and look for Mud On J-Bead.  Maybe that would work for you=mud-able J-bead.  Sort of a combo "L" bead
    1. housenut1 | Apr 09, 2010 12:24pm | #6
      Thanks for the tip.
      Mike
