Installing windows – thanks everybody!
| Posted in General Discussion on October 31, 2000 05:05am
A few weeks ago I asked for some input on installing new casement windows into existing structural brick walls. All of your great suggestions came into play. I just wanted to say thanks for the input and share my experience with anyone else facing this project.
First of all there are four major components you want to have on hand: Tapcon screws, mortar (to repair the loose brick ledges you are likey to discover on an old home), expanding foam (low expansion is important) and about 2-3 loyal friends.
Tips:
In my case there was no wood in the rough opening, so they needed to be framed. Also, the window manufacturer built very close to my rough measurements. I barely had enough room in the out of square openings to shim. I was very lucky to have room to plumb and level. Be careful when ordering, ask for the typical 1″ to 1 1/2″ clearance around the outside. You will need the Tapcons to secure your frame.
Double your muscle. These units are heavy and it is easy to forget how much extra grunt is needed to get them in place. We got them in from the inside so scafolding was avoided. A couple safety braces accross the opening meant we didn’t need to endanger anybody on the outside. If you are installing sashes (which I wasn’t) take them apart to save weight.
Be ready to move fast if you are in a northern climate like me. This may sound obvious, but the days are shorter and colder now and you will run into surprises. Expanding foam helps seal stuff up fast if you don’t have time for molding and caulk. You can keep living in the home until the trim gets done.
  1. Rein_Taul | Oct 31, 2000 05:05am | #1
    Tips:
    In my case there was no wood in the rough opening, so they needed to be framed. Also, the window manufacturer built very close to my rough measurements. I barely had enough room in the out of square openings to shim. I was very lucky to have room to plumb and level. Be careful when ordering, ask for the typical 1" to 1 1/2" clearance around the outside. You will need the Tapcons to secure your frame.
    Double your muscle. These units are heavy and it is easy to forget how much extra grunt is needed to get them in place. We got them in from the inside so scafolding was avoided. A couple safety braces accross the opening meant we didn't need to endanger anybody on the outside. If you are installing sashes (which I wasn't) take them apart to save weight.
    Be ready to move fast if you are in a northern climate like me. This may sound obvious, but the days are shorter and colder now and you will run into surprises. Expanding foam helps seal stuff up fast if you don't have time for molding and caulk. You can keep living in the home until the trim gets done.
