insulating an attic hatch
hacknhope | Posted in Energy, Heating & Insulation on October 4, 2006 06:10am
This should be an easy DIY job.  Access to the attic is a simple box hole with a wooden ‘lid’ that drops into it.  Seems like a very inefficient seal to an otherwise well sealed and insulated ceiling (this is in Canada).   The cellulose above is held back from the hatch with a simple wall of cardboard.
What do people suggest to replace the simple hatch lid?  Blocks of styrofoam?  Anyone got a good idea for an air-tight seal?
  1. Tim | Oct 04, 2006 06:20pm | #1
    My "hatch" is a piece of 1/4" luan sealed and sanded to sorta mimick the other smooth surfaces around it, with 6" of EPS (the rigid pink foam insulation) glued to to back/top. Fits snug at the bottom i.e self sealing MOL, inside a "well" of 2x12's to keep the blown in at bay and you can crimb on/through without damaging Effective r-value of this is 31 or so.
    jhausch | Oct 04, 2006 06:22pm | #2
    My builder is going to use 6-1/2" SIPS salvaged from the window cutouts.  I though that was  a great idea.  Not sure how to improve the seal in the opening.
    http://jhausch.blogspot.com
    Adventures in Home Building
    An online journal covering the preparation and construction of our new home.
    BossHog | Oct 04, 2006 06:31pm | #3
    I used a 1/2" piece of AC lpywood for mine. I had some leftover pieces of 2" foam that I glued to the back of it.
    I've wondered if there wasn't a market for an "attic access kit" - something that was easy to open, was insulated, and had a gasket of some sort for a tight seal.
    They'd sell like hotcakes at the big boxes.
    Both of my marriages have been disappointing. My first wife left me and my second one didn't.
      BillHartmann | Oct 04, 2006 07:01pm | #4
      http://www.batticdoor.com/index.htmlhttp://www.toolbase.org/Technology-Inventory/Interior-Partitions-Ceilings/attic-access-insulationhttp://www.rewci.com/enguinacha.htmlhttp://www.thermalid.com/http://www.modularstairs.com/insultatedatticstairs.htmlhttp://www.positive-energy.com/sealing/attic_insulation.html
  4. hacknhope | Oct 04, 2006 07:13pm | #5
    Thanks for replies.  Gluing on some EPS sounds good.  May even caulk it from the inside.  It's in a closet (appearance not an issue) and I'll bet we go years before we go up there again (now that wiring is done, new roof, no renos planned for now).
  5. Billy | Oct 05, 2006 06:26am | #6
    I like the SIP idea.  I've built insulated hinged boxes that flip up into the attic.  Use the high density foam gasket material on the mating surfaces and double-hung window twist locks to pull the box down tight for an effective air seal.
    Billy
