I need some opinions on crawlspace and floor insulation. If I use foam-board against the inside of the foundation, will this be enough to keep the floors from being cold? Should I skip the foam and use batting type insulation between the joists? The house was built around 1910, and is located in Iowa, usually it doesn’t get much colder than -20, and the house is pretty much sheltered from the wind. Any help on this would be greatly appreciated. Thanks
Wade
I need some opinions on crawlspace and floor insulation. If I use foam-board against the inside of the foundation, will this be enough to keep the floors from being cold? Should I skip the foam and use batting type insulation between the joists? The house was built around 1910, and is located in Iowa, usually it doesn't get much colder than -20, and the house is pretty much sheltered from the wind. Any help on this would be greatly appreciated. Thanks
Wade
