How do you insulate exposed trusses? thanks Elly
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
Greetings elly,
As a first time poster Welcome to Breaktime.
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Let's try running this thru again.
bump
Paint us a clearer picture, please. Are asking how to insulate exposed trusses in a finished out living space or exposed trusses in an unfinished attic space?
If you're saying that you want to, eg, insulate the roof of a garage with an open truss roof, it is indeed a pain. Your two best options are to install a ceiling and insulate the ceiling with blown-in cellulose, or apply spray-on foam to the bottom of the roof.
The other options involve tediously installing framing and blocking around the trusses to provide anchorage for drywall or whatever so that insulation can be installed above.
