I’m planing to insulate the crawl space under my 1880s house. I’ve been interested in using “Airkrete” formsulation. Has anyone experience with this product. Thanks in advance for your input.
Greetings lukes,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Peach full,
easy feelin'.
Thanks, the product seems to solve the issue of reguired fire codes and the expense of providing a fire barrier to other type insulations.`Anyone have experience with the airkrete product?
1. Our local earth tube installer uses 8" corrugated drain pipe. 4 ...- from BrianH, 7/23/2007
2. No, I'm not a dealer / installer of Airkrete. I did look into ...- from BigBill, 8/30/2006
3. New type of spray foam. I found out abought a new type of spay ...- from reinvent, 4/9/2005
4. * We also looked into AirKrete not to long ago. I found very ...- from hobus, 1/20/2000
5. insulation for crawl space. I'm planing to insulate the crawl ...- from lukes, 3/4/2008
6. I think it boils down to expected threats and how to plan for ...- from Constantin, 7/5/2007
7. Muriatic acid! It does a fine job. Mix with water,, ratio? 15% ...- from collarandhames, 3/13/2007
8. Using mutiple types of insulation. My house is undergoing a ...- from Jointerman, 3/5/2007
9. Google ''airkrete'' ...- from BigBill, 10/25/2006
10. airkrete.com ...- from BigBill, 8/29/2006
11. Don, Consider Air Krete, a blown in foam. Check out their ...- from Mike, 1/21/2005
12. Has anyone on this topic ever seen or used this product? It is ...- from Bill, 1/20/2005
13. sounds like Air Krete...pretty impressive product , but i only ...- from Mike Smith, 4/8/2003
14. * bill, you could look into perlite in a plaster mix.. but i don ...- from Mike_Smith, 3/6/2002
15. * Hi Earl, We are in the ICF business. We felt Air Krete would ...- from Norman_Williams, 1/20/2000
Peach full,easy feelin'.
Thanks again rez. Most seem to be doing research but no hands on. Had an installer come out, will get the estimate soon (?). I'm concerned about the price but internet suggests a price of about $2/SQft. Most available info says "it's Great" but an ad would say that.
Yes, seems to be a dearth of actually hands on comments regarding such.
Perhaps this round might shake someone loose.
Cheers
Ha..you said "Dearth"..sniggleSpheramid Enterprises Architectural Woodworks
