Insulation under laminated wood floor
I have a friend that has an existing laminated wood floor in den area that used to be a breezeway. The floor was just floated on the concrete slab with only a polyethylene vapor barrier. My friend likes to walk around in socks so the floor is really cold in the winter. I want to replace the floor and insulate under it. I have about 1″ to work with without raising doors and a slider. I was wondering if the standard 6mm foam underlayment is going to help at all. Or would I be better off using aluminum-backed 1/2″ or 5/8″ foam board followed by the underlayment. I have used this foam board to insulate finished basements and it seems to work great. It seem stiff enough to handle the weight.
"aluminum-backed 1/2" or 5/8" foam board "
Aluminum BACKED, but just some foil on it.
Foam has good conpressive strength, when spread out. But not in a small area.
I suspect that the edged of the laminate will flex enough to put force in consentrated areas and endup crushing the foam.
If you put a layer of plywood over it then it would work.
Hey every group has to have one. And I have been elected to be the one. I should make that my tagline.
