I found this outlet in a Motel bathroom. It was near the floor along side the toilet. I can’t imagine what that cord was for…but they did a great job cutting the hole in the cover….and at least it’s GFI protected.
Do you have to plug in an extension cord to make the outlet work?
Didn't try it...the cord part would not move.
Follow up question: What were you doing with your head down there?
Figured that was coming...never left my feet...
Ward,
If you wet your hands, then grabbed the left blade with one hand and the right blade with the other - and you're still here to post, then the outlet in your photos has an inlet - to something.
Jim x 3
Isn't the little light in the middle of that male plug, on ?
Isn't the light on the female end??? There was no light on it.
When they first came out with the cords with lights in them, many of them had a light in the plug end, as well. So you could immediately tell if you were getting power.And there is definitely a light on, in the inside of that plug...I'm not worried, I'm curious...You are always welcome at Quittintime
Thats the new night lites from China.Spheramid Enterprises Architectural Woodworks
Well if thats so, Don't pee on that nite light!!!
No lie!
If that's live it has lawsuit written all over it.
whatta 110 experience that would be
" the stimulus is working ".
Obviously to plug in the bath toys.
Mike
Small wheel turn by the fire and rod, big wheel turn by the grace of god.
That's a toilet camera.
Had some student electricians wire a school cabinet shop with drop down cords for the equipment. They put the male end on the live lines. Fortunately, it was noticed before they turned the juice on. Could have been a shocking experience.
Obviously, that was a unisex bathroom.
A hermaphrodite recepticle?Whenever government "gives" to one it must first take from another.
It's just another shameless plug ....
LOL
The last time they were remodeling the hotel the power was off so the contractor brought up his portable generator. Seems OSHA was on the job and the contractor didn't have a GFCI on the generator so they quickly wired in the only GCFI available with a stub to connect to the extension cord from the generator. If you pull the cover off you'll find the line input disconnected from the GFCI.
Where was it - geographically?
Heat tape for winter shut down?
Remodeling Contractor just on the other side of the Glass City
