Does anybody else find the mounting screws on elect devices just dont hold up. Had to remove a thermostat that I installed temporary to provide heat in the basement, had a hell of time backing out the screws, seem to have the same problem with switches and recepts.
Dan
yup.. just you...
since the arrival of offshore hardware...
WOW!!! What a Ride!
could be ya need ta get down ta gym more often...
WOW!!! What a Ride!
sounds like U are using the wrong size screwdriver?
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
can't get the vision of limp wrist out of my head...
ya sayin use a philips instead of a flt or vise-versa????Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
stripping in general ...
Jeff Buck Construction
Pittsburgh Pa
seems like ya find a lower grade of type F screws put into about everything now-adays... they act more like a pop rivet than a screw..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
