2100SF house slabed….
3 BR / 2FB / 1WC / full kit / DR / LR / remote 2 car…
on a scale of 1-10 level 7+ appliances / fixtures…
ICF to the roof… stuccoed.. (poly steel)…
Anderson 700+ windows…
clear trim and doors…
hip roof – metal…
Full HVAC. Radiant heat. 96/97%EF boiler domestic HW…
full copper plumbing…
slight overkill on the wiring…
tile – kit / baths…
hard wood remainder..
100$ sf budget.. possible????
cost add ons to what SF dollars…
70 miles from town.. (delivery surcharges on any and everything)…
where / what are the corners to cut???
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming <!—-><!—-><!—->
WOW!!! What a Ride!<!—-> <!—->
Edited 4/1/2006 6:54 pm by IMERC
Sounds too cheap, but where are you? I would guess a minimium of $185.
Colorado...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Rez will wanting to talk to ya 'bout nothing in yer profile...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Someone posted this on BT awhile back
http://www.building-cost.net/
It has a building cost calculator. Don't know how much stock to put in it, but it is fun to mess with. I don't know if it figures ICF's.
looked at that...
some body could get into trouble with that......Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
IMERC, round these parts, $100/'sq. would cover about 1.3 times the material costs for what you describe.
Guess I'm not much help other than to say that sounds way too low.
"Let's get crack-a-lackin" --- Adam Carolla
I think your labor rates are higher than ours. Right now, absolutely the bottom of the pickings is maybe as low as $125. If you're swinging the hammer on several trades, you might pull it off, but barring that, doubtful. I priced out a house just a couple of months ago not very unlike what you're describing. Change it to 2300 sf. My hard costs, even with hardie siding, almost no tile, were over $145.
The systems built shells I've had just a touch of experience with (and these are not mansions) they truck in a shell, you finish the roof, add the garage, provide the foundation and mechanicals, hook everything up, fix any cracks, build the stairs . . . those are coming in about 90.
Whacha got up the sleeve? This doesn't sound like fishing.
"Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
there is this issue about the painting that hasn't been resolved... ROAR!!!
friend's new mountain escape... on not much of a budget... it'd help to get a feel for figures in print from y'all so they can see for themself... right now they thin 100 is exorbinent.. I say it's about 65% down if we're careful...
even if ya don't have to leave the porch to fish it still doesn't make it less expensive...
I suggested Hardi over stucco... so what can ya tell 'em other than more gooder and last heaps longer and it's about ferever...
CRS bit me to the max... fer the life of me I can't remember the other more better than Poly Steel ICF's... ziltch on the search...
Can't remember what Wrecked Angle built his place out of either... dumped on the search on that one too...
that shell here is coming in at 115$SF.. all else is extra...
maybe I should mull this over some fishin' this weekendLife is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
"Can't remember what Wrecked Angle built his place out of either... dumped on the search on that one too..."SIPS.
that's why the ask... CRS sucks.. doesn't it....
I thought I had saved the thread... so much fer that thought...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
all I remember is the type of insulated panels and not the name...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
lets muddy the water... spoke wit the future HO
2100SF house slabed....
Westclift, Colorado...
3 BR / 2FB / 1WC / full kit / DR / LR / remote 2 car...
on a scale of 1-10 level 7+ appliances / fixtures...
ICF to the roof... stuccoed.. (poly steel)...
Anderson 700+ windows...
clear trim and doors...
hip roof - metal...
Full HVAC. Radiant heat. 96/97%EF boiler domestic HW...
full copper plumbing...
well...
septic..
electic service from gowd knows where...
slight overkill on the wiring...
tile - kit / baths...
100$SF budget.. possible????
cost add ons to what SF dollars...
70 miles from town.. (delivery surcharges on any and everything)...
where / what are the corners to cut??? what needs to classed as a luxery and trimmed...
WOW!!! What a Ride!
You didnt say what feuls the Dom Hot water ,radient heat and you want a SQ $#?
Are you on new meds yet?
And you are now phishing here?
WTF MARTY?
Code of BT is dont be an azzhole too much, you asking this shid about sq ft $ is rediculous..what some jerk wad will bid a job for your azz @ 9,000 FT ELE?
You sold yer shid, you went away, now follow thru with your absense, and I SWEAR I am not the ONLY one to request tha you be ALONE.
" Iam not a poet, but your hat is singularily inadequate"
Who put a burr under your saddle?
I apologize to Marty and y'all. I am really having a ruff time dealing with a fading mother 900 miles away, and a whackjob wife 9 feet too close. Sorry. Truly sorry, I ought not let the steam valve open here.
Get in your car and drive.[email protected]
Yup. That works good. Or exercise. I like to work. I just run myself into the ground until I'm not angry anymore. Healthy, huh?View Image
"I just run myself into the ground until I'm not angry anymore"
Yep, that works. Figure ya got another 10, 15 years before ya gotta come up with another strategy :-)
Actually I was suggesting he go be by his mom. I don't think I want and angry Sphere behind the wheel!!
Hell, his boss tried to kill some bikers just the other day.[email protected]
LOL
and sphere could end upletting his rednick neighbor bailing HIM out
Code of BT is dont be an azzhole too muchmerits another read...for those writing as wellcan you be an azzhole to little?
Barry E-Remodeler
Geez, you two married or something? DanT
Sounds like they will need to do a lot of DIY nlabour to get that one done.
Arxx bloicks is the ICF thaat I use
can't figure out where to cut without going cheap..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Arxx.. is that spelling right...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
http://www.google.com/url?sa=U&start=1&q=http://www.arxxbuild.com/&e=9797
Is the well, septic, and seperate 2 car garage included in that 100/sqft number?edit: and bringing in electric?bobl Volo, non valeoBaloney detecter
Edited 4/3/2006 12:46 pm ET by bobl
of course... and the propane too......
the land is paid for....
their line of thinking is 2100SF x 100$ equates to 210K...
there is only so much you can pack into this.. something has got to be given up... I got a buck sixty - five without persueing the fine details...
is that what happened???
hmmmmmmmmm......
WOW!!! What a Ride!
is that what happenedDon't know, just readin tween the lineshere. But, alas I've already said to much........ <G>
so lets get on with the original thread....
how we gonna trim with out being cheap and build this last house... Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
