Joining drain vents
JohnT8 | Posted in Construction Techniques on October 13, 2005 11:37am
I noticed an a Habitat house I helped on last year that in the truss/attic space they had routed all the plumbing drain vents into one pipe and therefore only one roof penetration.
Looked like a neat idea.  Anyone know what the restrictions on doing this are?  Do you have to increase the diameter of the pipe as you add different vents to it?  I can’t remember how large the roof penetrating pipe was.
You’re paying for more PVC to run them together, but the fewer roof penetrations I have, usually the happier I am.
“Holding on to anger is like grasping a hot coal with the intent of throwing it at someone else; you are the one getting burned.”
— Buddha
  1. DanH | Oct 13, 2005 11:40pm | #1
    I suspect that this wasn't done traditionally because it's easiest to have CI pipe run straight up. No reason not do do it with plastic, AFAIK. It was done in our house, built in 1976.
    No electrons were harmed in the making of this post.
  2. JohnSprung | Oct 14, 2005 01:00am | #2
    Glancing at the code book, the things that look relevant are:
    + Total cross section area of vents thru the roof equal to building drain size.
    + Vent run longer than 40 ft. must be one size larger for entire length.
    Combining in the attic and making only one potential leak sure sounds like a good idea.
    Some sort of screen over the big pipe might also be a good idea.  Back in my Venice Beach days, I had a tenant who went on the roof and thought it was cute to drop an empty beer can down a vent.  Flooded the basement.
    -- J.S.
    1. DanH | Oct 14, 2005 01:13am | #3
      Screen isn't a good idea in frost country. The screen can ice up and block the vent.
      1. Danno | Oct 14, 2005 02:53pm | #6
        Don't use screen, use hardware cloth (which is "screen" but with coarser squares--the wires can be something like an eighth inch apart on up to a quarter inch apart or more). Is stronger than screen to and will keep critters out. The eighth inch grid may even keep wasps from building nests in the stack, but may also frost up and block the vent (or let snow pile up).
  3. brownbagg | Oct 14, 2005 02:18am | #4
    I did it to mine, nothing illegal, only thing its doing is equalizing the pressue as it drains.
    1. JohnT8 | Oct 14, 2005 08:36am | #5
      As long as it all points up, I couldn't think of any problem with it, but I've never used it myself, so didn't know for sure.
      But between the trick of running all the vents to one roof pipe and maybe plumbing with PEX... seems like a lot of potential headaches could be removed.
      "Holding on to anger is like grasping a hot coal with the intent of throwing it at someone else; you are the one getting burned."-- Buddha
  4. moltenmetal | Oct 14, 2005 05:48pm | #7
    If you're in a heating climate, make sure any horizontal vent runs in unconditioned space are well sloped back to the source or the condensate will freeze in them.  Same argument as running the vent horizontally through a gable wall.
    There are other critter-proofing weather-cap options than screen.  Just make sure there's some kind of venting cover on there or you may end up with a blocked drain like my neighbour did.  It seems the squirrels liked the sound the walnuts made when they dropped them down his stack, so they loaded it up with over fifty of 'em!
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
