jotul 602 or f 100 nordic
Floss | Posted in Energy, Heating & Insulation on October 14, 2006 03:25am
I am considering purchasing either of these wood stoves.
Just curious as to anyone who has some personal experience with either of these units.
I am looking at heating around 700 square feet.
I like the size of the 602 but may be a little concerned with creating a hot/cold cycle since the firebox is rather small and may need more frequent tending.
On the other hand the 100 has a bigger firebox and will that one run me out of the house bringing it up to temp?
And how much, if any, soot/smoke is generated by these things when starting?
I know these questions are a little broad, but I am grateful for your help.
I have an 8″ clay lined flue with a 6″ thimble for the pipe. I think the previous owner used an oil or gas stove to heat the place when it was first built.
Lastly is there any maintenance needed for the stove? I know the flue and pipe will need to be cleaned periodically.
Thanks again.
J.P.
  1. user-67934 | Oct 15, 2006 08:39pm | #1
    I have a Jotul 602 in my house. It is a small ranch style house just under 1000 sf. The stove is in the corner of the house and it does a great job heating the house. It won't hold a fire overnight.
    1. Floss | Oct 16, 2006 03:58am | #2
      Hi Tony,I put a deposit on the Nordic 100. My wife saw the 602 and didn't care too much for the style. I liked it. She wanted to see a little more of the fire.I think it should work out well.By the way, how tall is your flue? Is it masonry or steel pipe? I was a little concerned that we have an 8" masonry flue that is only about 10' since we have a small ranch as well. I was told that a shorter flue of large diameter may not draw as well as a smaller diameter flue, therefore it may smoke some when starting a fire. I guess I will find out soon enough.Have you had yours for long?ThanksJ.P.http://www.jpkfinefurniture.com
  2. grandizer | Oct 16, 2006 02:44pm | #3
    Don't have experience with either but I've been looking at the 602. I'd only offer as advice, to look at the clearances to combustibles which can be problematic in small spaces.
A New Approach to Foundations
