Kitchen Cabinet install
breidel | Posted in General Discussion on March 12, 2008 04:18am
Labor to install new kitchen cabinets in new home? The cabinets are in the house, granite guys to install the tops.    Should I price by the box, or by the hour?
Thank you.
  1. calvin | Mar 12, 2008 04:27am | #1
    How many kitchens have you done?
    http://www.quittintime.com/
  2. hvtrimguy | Mar 12, 2008 04:38am | #2
    A word of caution. If you charge by the box and the designer has you going back multiple times to finish odds and ends due to missing parts, damaged items, mistakes in the design, customer unhappiness issues, taking up slack where the builder leaves off (moving appliances, doing ductwork, getting cabinets into position from garage or something then be prepared to make very little. If I know the designer, have done several kitchens with them and they have a good track record, they have earned the per box pricing. until then I charge by the hour plus travel time for those 20 minute last details that required a 1 hour drive each way.
    "it aint the work I mind,
    It's the feeling of falling further behind."
    Bozini Latini
    http://www.ingrainedwoodworking.com
    1. hartlandboy | Mar 12, 2008 05:39am | #3
      It's really good advice from Bozini.
      Gary
    JeffBuck | Mar 12, 2008 06:15am | #4
    "Should I price by the box, or by the hour?"
    wadda ya mean by "price"?
    do U mean figuring your set bid out by either?
    or do U mean that charging by the hour , no set bid, is an option?
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
  4. susiekitchen | Mar 13, 2008 12:58am | #5
    Good advice from all.
    As a designer I price by the box, but I also figure in at least 1 extra trip charge for any job. For those where the job and/or customer is fairly demanding, I may add a couple of trips. That way my installer knows the exact amount he gets for the install and also the minimum he can expect for a call back. Keeps me in good stead with my installers.
    As far as pricing by the hour, be sure you factor in the time it takes to actually set up to start work, especially if you think you may have to make several trips to a jobsite.
Episode 1: Drywall Tools for the First Coat
Learn about mechanical and automatic tools such as the taper, the compound tube, and the banjo to make your drywall job better and easier.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
