I’m putting down pre-finished oak strip in my kitchen.
Rosen paper or 15lb felt??
House is in northern NJ, 25 year old split, plywood underlayment. I know this has been talked over before, but I didn’t have much luck doing a search.
Thanks for any and all info.
Andy
Hey Andy, having seen this question posted many times before, I think you're going to get more of an election result than an answer.
My vote is rosin paper. Felt smells like tar for a good while (just my experience -- maybe my nose is too sensitive?). I've seen a lot on using felt on the first floor to keep moisture migrating up from the basement from getting into the floor too quick, but I've not had a problem with that (knock wood). ;-)
"Let's get crack-a-lackin" --- Adam Carolla
Thanks - I didn't even think of the smell The floor is over the boiler room and part of the garage - both bone dry
there won't be any smell after the floor is down...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
phil is clueless...
go with the felt...
it will out last yur great great grand kids...
works better too...
WOW!!! What a Ride!
>>"phil is clueless...
Stop mincing words. What are you trying to say? ;-)
the debate is now in session...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
>>"the debate is now in session...
ROAR!!!
You hit that nail square on the head. I got my seatbelt fastened for this one. ;-)
BTW....
is yur chair bolted down...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
IMERC
What makes it better? Thicker, stronger? More durable?
Thanks for the reply
Andy
quieter, better VP barrior, out preforms and out last rosin...
during the install rosin will tear very easily...
when yur sink over flows the felt won't care and the rosin will start the rot process..
been doing it that way since the 50's and have a fairly good tract record...
I learned that from my father and he from his...
priciple reason for the paper is for a quieter floor....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
"out preforms and out last rosin..."
if it ain't gonna smell after U lay the floor ... it certain ain't gonna tear!
my gran'dad says yer gran'dad is wrong ...
rosin paper it is!
Jeff Buck Construction
Artistry In Carpentry
Pittsburgh Pa
yur just sayin' that to make phil happy...
rosin tears during install...
rosin desinagrates over time...
rosin doesn't do squat to stop air flow..
can we spell drafty floors...
taking floors up that had felt and those that had rosin...
convinced me not to bother with rosin....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Felt smells like a refinery. ;-)
Oh, wait; I already conceded.
Forget that.
Edited 4/25/2006 11:21 pm ET by philarenewal
to the victor goes the spoils...
where do you want this bill for my coffee sent...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
>>"where do you want this bill for my coffee sent...
Can I run a tab? I have a feeling it won't be the last coffee I'm buyin . . . . ;-)
sure....
probably do a trade out...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Just sent it to me.I am still waiting for a couple of carloads of kibble.
You accept a third party kibble? ;-)
Hey,I am getting desperate.And Max, the mut, is trying to chew on my leg.
even though I like Phil better than U ...
seriously ... I use rosen.
and stop throwing those boards around while doing the install ... the paper will stop tearing!
besides ... if I didn't use rosen for floors ...
where else would I use it?
gotta use it ... hate to see a whole industry go away ...
plus ... it's prettier ...
Pittsburgh Pa
They say once you go Black.............
that's a myth ...
plus ... it only makes the floor look bigger ....
Pittsburgh Pa
use it on top of the floor...
helps keep finished floors looking nice...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
that's where I put my 15 lbs felt!
Pittsburgh Pa
consider the paper between the floors as a bearing plate when both of the floors ar moving in different directions...
let's keep a lot of those squeaks in check if you will please...
rosin paper will wear...
rosin was developed as a cheap-er alternitive....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
IMERC
Thanks for the info - felt it is
alrighty then...
did you pass this on to phil...
he was still strapped to his chair the last we knew...
or should we just leave him there for safe measures...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
>>"alrighty then...
Not so fast my friend. The rosin paper crowd will be along soon enough. ;-)
evidence is in....
and they'll just havta keep movin' right long.....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
I won't concede 'till 24 hrs. have passed. ;-)
alrighty then...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
You win fair and square.
I concede the election. ;-)
and ya don't even have pay any kivk backs..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Everyone has a reason why to use one or the other, but I just tore up a 70 year old floor that had 1/2 rosin and 1/2 felt. (I guess the original builder ran out of one or the other 1/2 way through the job.) The rosin paper was essentially dust. The felt was still intact. I used felt when I replaced it.
Mike Hennessy
Pittsburgh, PA
I prefer felt.
J. D. Reynolds
Home Improvements
BTW... what is split plwood other than damaged...
WOW!!! What a Ride!
I think I would go with 30 lb.
that's even a better move..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
I feel felt is better and just read where 30# is a vapor barrier and 15# is not so much so. Hey, who's for plastic?
