In every ones opinion, what is the best way/product to conceal, hide or camoflauge a seam in laminate. Especially light colored laminate.
Thanks,
Will
Thanks,
Will
Hide it in the sink cutout if possible. If not get the seam as tight as you can by doing a mirror cut. Formica, Wilsonart, ect. make seam sealer. A type of epoxy that comes in several colors and can be custom mixed to match. Works well if the gap in the seam is not to large.
*I do quite a bit of laminate work, and I would never-never-never put a seam where sink cut-out will be. Water, Murphy's law etc.. When joining a seam , never use a factory edge, make your own. Seam seal or a matching caulk type tube is generally available fron the laminate supplier. Assuming your getting it from a cabinet supply supply house and not a hardware or home supply "depot".
*Home Depot sells Seam Fill - kit of several tubes or individual tube of your color if yours is a solid color.
*A well glued seam is fine under a sink cut out and is usually less visible.
*I also put my seam in the sink opening . I haven't had any call backs yet.
Thanks,
Will
