What is the best way to check a rented laser level for accuracy? Or can you just trust them because they’re always right?
The best tool for straight, splinter-free cuts is made even better without a cord.
casey. Set up and mark the beam locations in four diff. locations. Move the laser to a different spot, mark these beam locations, measure the difference between the two. Same measurement, laser ok. Diff measurement, bogus.
__________________________________________
http://www.quittintime.com/
get a water level and check the laser against that. You can get one that has 50ft of hose for about $12.00 that is accurat to 1/16 of inch over 200 ft. If you need 200 ft you just add more hose. :)
