I have a 2 story gable end facing west, twin d.h. windows 1st and 2nd floor, stacked. Brick veneer over 2×6 framing, no house wrap or felt paper between brick and osb sheathing. Also, no flashing above windows, just steel lintels. About a 1″ air space between brick and osb. Brick work is flawless, no cracks at all. Windows are completely calked to brick. I’ve applied sealer, Prime-a-pell, multiple coats, wet on wet as per instructions about a year ago. Whenever there is a driving heavy rain from the west, the 1st floor windows leak at the heads inside. Any options to fix other than tearing off the brick?
wur
can you post a couple pictures of this? Long full shot of that side of the house, more close up of each full window and then detailed shot of the bottom of the upper and top of the lower. Inside photo of the leak locations noted.
if flanged windows, are these just set in caulk, nailed on the sob and called done?
any weep holes in the brickwork?
thanks
Concerning yourself about whether the windows flanges are properly caulked at this point is like checking to see if your wooden boats hull's been properly chinked as it's being steered directly into a rocky coastline. It's going to sink anyhow.The OSB that the windows are set into have probably been steadily turning to mush from chronic vapor drive.
no kidding
I didn't misspell OSB, and should have made "just" bigger font.
does that help you understand?
thanks
Something is wrong
One of these two statements can't be correct:
" Brick work is flawless, no cracks at all. Windows are completely calked to brick."
Rainwater is gaining entry. You need to determine where before you can ascertain how to fix it. My guess is the problem lies with the upstairs windows. If they are bad, I'd assume the lower ones are also. As well as the doors, and any sidewall vents, pipe entrys, and the like.
I agree....
As Sapwood states above, the first culprit to look at would be the sill of the upper windows....and by default, the window sills of the lower wall... Unbelievalbe the builder would not install any kind of vapor barrier behind the brick..your situation could be really bad - the chance of rotting the OSB is very real. That area will always be damp and, with no ventilation, rot and mold will shortly follow. I predict serious problems are in your future.
wurx24-7 wrote:
no house wrap or felt paper between brick and osb sheathing. Also, no flashing above windows, just steel lintels. Any options to fix other than tearing off the brick?
You've identified the main culprits of your problem. No matter how it looks from the outside, your brick work is not as flawless as you might like to believe. A good mason would not lay brick veneer without proper moisture barriers, flashing, and weep measures in place.
Hate to say it, but looks like you are in for a sizable demo and masonry job redo.
You could always tear it apart from the inside, but without knowing how much remediation you need it's hard to say whether that would be sufficient. The whole setup sounds like a disaster.
While they are far from perfect, masonry sealers should be sufficient to prevent rainwater from being driven throug the brick in large amounts over a short period of time. Most likely there's an actual leak somewhere, possibly in the gable.
When they're right, they're right.
Knowing that you own the titanic, I would look to the area just above the bottom window. You need to fix the leak here anyway, so have another Flawless mason take off some courses above the lintel. He(or she) can then flash and seal above the window and ascertain the extent of the damage. While it is open, try to find the leak above. You will need to "tent" the lower window so water can be seen from behind the brick and not the exterior face. It may not be as bad as we think if the upper window itself is leaking and only on occasional rain events.
Good luck!
