I have been asked by a good customer to work up a rough number for finishing out a loft condominimum. Can I price it like a regular house with no roof, foundation, window, etc costs? I have not seen it yet. I assume there is a plumbing stack to tie into, and maybe a central a/c unit. What pitfalls might I see? Material staging area & parking come to mind.
I’m sorry, I thought you wanted it done the right way.
Add in bad vertical access (U stairs, or circular stairs). Also, COA rules about noise, "tradespeople" access, notification rules, etc. Just presume you won't be allowed a port-a-let, whihc means the only working john will require major changes the whole project (like the song says--don't ask me how I know).
Oh, and make no assumptions about what structure is under the skin of the walls. Well, you can, if you set in your mind that it's reject 2x3 & 2x2, and cast-off pallet parts, instead of any sort of proper framing. (If it's nominal framing, and anywhere near on center--that's just a big fat bonus).
Oh, and it's worth getting some cheap-as-you-can magnetic signs for your vehicle, and matching #### and/or hats. Get some extra business cards, and have them handy--you will be asked many (many, many) times what you are doing, sometimes by the same people repeatedly. (This is some worse if they are under the assumption that contractor=not crooked enough to sell used cars, but close.)
Ah, and you will need not only the COA point-of-contact, but also any local manager/POC. The first thing you need from both of them is how to handle construction debris. It is a major pain to bring your own dumpster, and then only from 0900 to 1630, to the site every day.
