I have a Majestic gas fireplace to install. It is factory set up for Propane. What I need to know is what kind of gas line should I use to hook it up to the two propane tanks I will be using. The manual recommends copper piping. If I go with copper what size should I use. Can I go to a flexible type of line where it connects to the fireplace burner. If so what kind & size. I will be purchasing what I need at Home Depot. It will be installed along an exterior wall so the total run of fuel line to the tank regulator will be about 20 feet. Any other recommendations you folks can give me for installing this unit will be greatly appreciated.
